Announcements
Rendering renders hidden parts
mailVBRKD
mailVBRKD
Hi, I got problems that my project is not rendering correctly.
This is what it looks like and what I want to render:
There are problems both in in-canvas renderer and in renderer.
1. The in-canvas renderer is missing a lot of parts
2. This is what "Render" gives, which is better, but still bodies rendered that should not be renedered.
I have attached the project.
Thank you.
TrippyLighting
Yep, that’s a bug that has been reported quite a few times, but has yet to be fixed!
jakob.krantz8VJGE
Community Visitor
Community Visitor
Dang, thought I did something stupid as this seems to be a "trivial" feature that should work.
Do you know of any workarounds?
TrippyLighting
Question: does this behavior change if all the parts are updated to the latest version?
I see aa lot of yellow triangles in your screen shot
mailVBRKD
Updated all to latest but same things unfortunately.
jakob.krantz8VJGE
Community Visitor
Community Visitor
Now the "in canvas renderer" does not work at all anymore. If I start it nothing happens and Fusion UI hangs. I can still change project, but the renderer keeps drawing "ontop" and I need to restart Fusion to get it useable again.
sliminator_the_first
Observer
Observer
Faced the same problem today for the first time, and fortunately, found a solution. So you have to hide all the bodies that you don't want to render, however the trick is to hide them not in DESIGN enviroment, but in RENDER enviroment only. If hidden in DESING, unhide them, go to RENDER, then hide again. This doesn't work with folders/groups, you should hide each body separately.
