Announcements
render a reflective logo
Hi all, is it possible to render a logo with reflective tape? My object is a visor for cyclists and it would be great to make the logo more visible in the dark.
TrippyLighting
This will probably require a workaround as I don't think that there is a material, which allows properly rendering retro-reflective tape. YOu might simply apply an emissive material to the logo.
If you can share images or even the model that would probably go a long way in getting help!
Thank you for your answer. I want this logo (which is a decal) to be reflective. I'm not sure an emissive material would render it well, but I'll have a try.
ak3362
Observer
Observer
In the future, you can probably use an emissive appearance.
Oops I see this was already solved
