Announcements
Renaming Mutiple components quickly
r.chandraQ38SV
r.chandraQ38SV
Hi Fusion users,
I need to rename about 33 bodies (all the same name)
Is there a way to do it in one go?
I have used the shift key to select all the bodies at once, but I cannot find the rename command.
Please see screenshot:
Thanking you all kindly.
Raj
jeff_strater
No, there is no way to change component names all at once.  You cannot name them all the same - each component must have a unique name (that is why the current components all have suffixes like "(1)", or "(1) (2)").  I cannot tell from the image, but if all those components are using the same geometry, they should be instances of one component, not separate components.  That would also solve your requirement of them having the same name - since all instances of a component share the same name as well as geometry.
Jeff Strater
Engineering Director
r.chandraQ38SV
Thank you Jeff,
Will most certainly try your solution.
Raj
