Announcements
Remove faces in brep
I am having an issue with reducing faces in brep
TheCADWhisperer
Can you Attach the original file here?
The forum is currently broken - you must Reply and the Edit Reply to get access to the Attach button.
jeff_strater
This appears to be a model converted from a mesh.  The time to remove faces was BEFORE the conversion, not after.  Use the Mesh Reduce  command to do this before conversion:
Jeff Strater
Engineering Director
