Reinstall problems
Reinstall problems
hg49KUU
Reinstall problems
hg49KUU
I am trying to reinstall Fusion 360 (trial) - it kept freezing when I selected the trial counter, so I uninstalled it, intending to reinstall it. But now the installer appears briefly on the screen and then vanishes and nothing more happens. Would appreciate some help. Thanks. Regards, Henry
James.Youmatz
Autodesk Support
Autodesk Support
Hi @hg49KUU,
Welcome to the Fusion 360 Community!
I am sorry to hear that! Just to check, have you tried restarting your computer then running the uninstaller? Also (if on Windows), what happens if you right-click the installer and select Run as Admin does that work? If you keep task manager/Activity monitor open while installing does the process eventually disappear?
Can you also please gather your installation log file (guide here) and post it?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
hg49KUU
Thank you very much! Run as admin did the trick and it looks like it's
installed successfully. Thanks again,
Henry
James.Youmatz
Autodesk Support
Autodesk Support
Hi @hg49KUU,
No worries! To prevent any update issues (as this may occur in the future), I would suggest right-clicking the desktop Icon for Fusion and selecting Properties. Then scroll over to the Compatibility tab and check the box to run Fusion as admin on start up. That way it is always running in admin mode and you won't need to worry about any permissions issues.
James Youmatz
hg49KUU
I have done that. Thanks again for your help.
H
Hey, I have tried all of the above, however, when I go and attempt at uninstalling, I begins streaming, thus making it impossible to do
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
How are you uninstalling? Is it from the Control Panel? If so, can you try using our clean uninstall tool here and then reinstalling?
James Youmatz
