Announcements
Reference parameter of Insert Component.
LiveLover
LiveLover
Hello!
I have a Design_A, it has a parameter val=33.
I insert it into Design_B via (click on Desian_A in Data Panel -> Insert Into Current Design)
But it does not allow to access Design_A::val parameter (or I do not know how to).
We can try to insert Design_A into Design_B via Insert -> Insert Derive. This method gives us access to Design_A Favorite parameters, but it "discards" all the Joints Design_A has.
May be this inserting method omits other things. Please tell!
When I try to combine these import methods to insert whole design (first method: not separate objects) and parameter (second method). Fusion does not allow me it. May be you know how to apply both imports?
My workaround:
I store val=33 in serperate file lets call it Design_A_Base. I insert it via second method in both Design_A and Design_B. And I insert Design_A into Design_B via first method. It works.
Please suggest other solution.
Thank You for any your explanations!
g-andresen
take a look at Master Parameter   by @jhackney1972
günther
LiveLover
 Guenther Andersen, thank you for this link!
Video describes in details the solution I called workaround in my question.
I wonder is this the main generally accepted approach?
May be there are alternatives?
g-andresen
Just so much, for me it is a solution and not a workaround.
günther
