Reference Failure/Cached Geometry
emisnug
emisnug
Screen Shot 2019-03-30 at 9.00.09 PM.pngI'm trying to join two components, and I get this error - in a previous version of the model, they join together fine. I've made an assembly with these two things (a bearing and a plate it goes in) before and it's worked. It's just... stopped. And it's bugging me, because as far as I can tell it should work perfectly. Nothing is cached, nothing has been modified. I've also tried to export the f3d, it just errors out.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @emisnug ,
That is strange. So no earlier features that reference the two components were modified? I.e. a change to how the component was created that was then used in that joint? One thing to try to get it to disappear (and see if it comes back) - right-click the feature and select Edit Feature and then select the two components again. After that, go to the Modify menu and select Compute All to recompute the timeline. Is the warning still present.
Also, will it let you save the file now. Can you expand more on the save failing?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
