Redo button deletes geometry
eerier_bleach0f
eerier_bleach0f
Add fillet > hit undo > decide I shouldn't have hit undo button so hit redo > fusion deletes geometry:
Here's 2 examples:
FileName: AddedFilletHitUndoRedo
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
jeff_strater
I apologize, but I do not see a problem from those videos.  Undo and redo seem to be performing as I expect.  Both start out with a model state where you are positioned in the middle of the undo stack.  Redo can and should delete geometry, if that is the state that the model is in.  You said that the sequence prior to this involves creating a fillet then deleting it.  Can you illustrate that sequence?  That is, show applying the fillet, then undo, then redo?
Jeff Strater
Engineering Director
eerier_bleach0f
If I have this box:
And then I add a fillet to the top left edge, the model should look like this:
If I decide I shouldn't have added that fillet and I hit the "undo" button the model should look like this:
If I then decide I'm an idiot and I actually do in fact need the fillet, hitting the "redo" button should bring the fillet back and my model should look like this:
It shouldn't look like this:
Hitting "redo" should bring back the fillet, not delete faces.
I did not say this.
"I" am not deleting any geometry. All I am doing is creating a fillet and then hitting the "undo" and redo" buttons. Fusion is deleting geometry.
jeff_strater
that is not the experience that I see.  Do you do something different in your example?:
Jeff Strater
eerier_bleach0f
Great so in the video you just posted I see expected behaviour: You hitting the "redo" button reapplies the fillet and nothing more.
In my videos when I hit the "redo" button Fusion deletes faces:
I did not delete those faces. I need those faces. All I did was hit the "redo" button so I can bring my fillet back. But now I can peak inside my model.
jeff_strater
this feels like it is a graphics issue, not a geometry issue.  It could be the graphics driver on your computer.  I have not heard of anyone else seeing problems like you describe, which leads me to believe that this is not a general undo/redo geometry issue.  Please feel free to share the design with me at jeff.strater@autodesk.com, if you would like.  Preferably, share the model in a state before the fil...
Jeff Strater
eerier_bleach0f
This probably is a visual issue. Or a visual issue caused by another. I have a similar issue to this.
I pushed this face:
To be flush with the top like this:
Like in the image above it did what I wanted. But then I hit the "enter" key to apply the change. But it gave me an error and wouldn't make those faces flush. But after hitting "Enter" Fusion also removed the vertical faces like so:
And then I zoomed in and it brought the faces back.
Last week I completely wiped my computer and reinstalled the OS.
Sometimes like in the video above, hitting the undo button to revert back and then redo button brings the faces back, other's it does not.
