Rectangular pattern not working
navpat
Message 1 of 8
navpat
Hi all,
I tried using rectangular pattern to make a pattern out of a criss cross pattern I created (attached in image). But its not working. The arrow doesn't show up to make copies of my pattern. What can I do?
Please help. Thank you.
Replies (7)
Message 2 of 8
davebYYPCU
Normal to complete the dialogue boxes from top to bottom,
In that picture, there is nothing selected, and no direction stated,
When doing those, the lower down particulars usually reset.
Might help....
Message 3 of 8
TheCADWhisperer
Message 4 of 8
navpat
For sure, I've attached it 🙂
Message 5 of 8
navpat
I'm unable to select any faces
Message 6 of 8
jhackney1972
The image you posted is a sketch, you have to be in the sketch environment to select it as a Rectangular pattern.  I used a window selection method but you have to fill in the Rectangular dialog box from top to bottom as suggested before.  Screencast will explain.
If you are planning to Emboss this pattern on the ring, I would consider Embossing the pattern, as it is, and then Circular Pattern the feature in the modeling environment.
John Hackney, Retired
Message 7 of 8
navpat
Thank you so much! I was able to do rectangular pattern. But I couldn't do Emboss nor circular pattern. I've attached a pic and the f3d file. Please help.
Thank you.
Message 8 of 8
navpat
Actually I just figured it out. I couldn't emboss because the length of my pattern was too long. Thank you once again
