Hi there,
I'll say straight off I'm used to SubD and procedural modeling (Modo, Houdini), and some MoI, so the Fusion 360 paradigm has, well, let's say it's not coming easily. It feels like trying to step backwards into layer-based work after experiencing node-based work - extremely limiting and lacking flexibility/power. Anyway.
The issue I'm running into is this: make a sketch, extrude it "to object" (i.e. to a construction plane). Do some other work, including making new planes. Then decide I need to change the target of the "to object" extrusion of that original sketch. However, when I go to do this (by right-clicking on the extrusion and saying "edit feature"), the new planes disappear...
I assume this is because I've "gone back" in the history before I added the new plane?? This seems... Insane, basically, from a design perspective. The two histories should be entirely separate!
Sure there is a way to do this...
