Announcements
Re: Fusion 360 says that "We are currently updating our services".
Hi. I have some problem: Fusion 360 says that "We are currently updating our services". I tried to delete NsCloudBrowserCache_myhub.dat and LoginState.xml files. It's not helped.
This is my DiagnosticLogs file.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for sharing the logs. From the logs, I can see some network errors.
20180430T193438 E CloudBrowser failed request - exception: WinHttpSendRequest: 12029: Не удается установить соединение с сервером
...Uri: https://developer.api.autodesk.com/wipdata-serv/storage/v3/system ThreadID: 11236, Function: void __cdecl Ns::Network::RequestMgr::RunRequest::<lambda_fbd3533c4406b22230b6b3aa909d3b93>::operator ()(class Concurrency::task<class web::http::http_response>) const, Line: 378
Just to check - are you on a school/private network or is this a home network? Are you able to reach https://developer.api.autodesk.com/wipdata-serv/storage/v3/system from a web browser, or does that fail as well. Is there any anti-virus or proxies on the computer that may be preventing Fusion from reaching this URL via the Fusion client.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thank you for your help. It really was a network error. I didn't able to open the page https://developer.api.autodesk.com/wipdata-serv/storage/v3/system from a web browser. Now I solved the problem.
marc.wintermantel
Since about 5 days fusion is always offline saying that it is updating its services. I tried to check if there is a network issue but could not find any as all my other applications requiring internet are running normally. Attached is my diagnostic log.
rrwright783KF22
Community Visitor
Community Visitor
I had NORD VPN running. turning that off fixed my issue
