RE: 3D Blocks in CAD appears OK but could not export to Fusion
catherinetam
catherinetam
Hi there,
I typically do my drawings in AutoCAD and have them exported to Fusion to do my renderings however I've encountered an issue now. The 3D blocks appears fine in my AUTOCAD but completely disappeared after I've imported it into Fusion. I've tried reconstructing everything from scratch to reduce the block size and it still doesn't work. What could be the issue? 😞 In dire need for an advise as I need to submit this for a deadline 😞 Thanks!
TrippyLighting
@catherinetam wrote:
Hi there,
I typically do my drawings in AutoCAD ...
Stop doing that and start modeling your things in a model parametric 3D CAD software.
Around here we prefer Fusion 360 😉
It might require you to forget some of the practices but it will be well worth it.
What is it that you have to supply by the deadline? a 3D model, renderings, or a set of 2D manufacturing drawings?
I'd be more than happy to help out if you transition to Fusion 360!
