Announcements
Ran into an odd error and found a solution, might be useful for some
PROGRAMMING7K5CY
PROGRAMMING7K5CY
Was working on my senior design project for school and ran into an odd issue which prevented me from saving the file. As seen below I found this error was present previously resulting from text being in sketches and using the manufacture workspace. I had done neither of these and had not saved my work in a few hours. I am unable to replicate the issue and was unable to export it in it's broken state. Hopefully this bug does not persist although I saw someone recently post with this issue and wasn't able to get any help.
I was able to resolve this error by rolling back the design history to the start and slowly saving the file while rolling the history forward a few steps at a time. A bit tedious but my file and night of work is safe.
Hopefully this helps someone.
"Error: The source asset FusionAssetName in document attempt v3 has not referenced the target asset FusionAssetName in document Link V2 v3!"
Phil.E
We identified an issue recently that might be related to your experience that is now fixed. Can you try these steps and let me know if it helps?
1. Restart Fusion 360
2. Try your workflow again
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
