Hey everyone,
since a couple of days, my upload is pending with no end.
I can still work on the files and when I add new parts, the queue also gets longer, but no files are uploaded. Also on the online page I see that the last uploads were a few days ago.
What I have already tried and found out:
1. I have already cleared the cache, unfortunately that did nothing.
2. Uninstalled and reinstalled Fusion 360. Did not make any difference.
3. Switched to offline mode and saved the data again. Then switched back to online mode and saved again. Did not change anything.
4. Tried the following instructions: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fil...
Unfortunately, I always get the following error:
5. Diagnostic files created and uploaded in the attachment.
6. In: "C:\Users\***\AppData\Local\Autodesk\Autodesk Fusion 360" in deleted the folder "RHREKXYWDR2T". This makes the data in Fusion a few days old again, but the upload works again! The folder again contains a folder called "W.Login", this is 500MB in size, if that is somehow relevant. However, since I would like to keep the data I have worked on over the last few days, just deleting the folder is not a solution.
Maybe someone here knows more. I'm slowly a little on the hose, what else it could be.
Thanks in advance.
