I am having an issue with my model where Fusion 360 gives a "missing profiles" error for a revolve feature when I change the profile sketch using a parameter. The sketch is just an ellipse and the parameter I'm modifying just changes the width and height of the ellipse being used for the revolve feature. Changing these parameters does not delete the profile I had selected so I'm not sure why it causes this error. Re-selecting the profile fixes the error and all subsequent errors down the timeline. However, I really need to be able to change this parameter dynamically from the Parameters menu as this model will be used by others who are not savvy in fixing Fusion 360 errors.
The parameter in question is ConcaveIntensity and the sketch it affects is called Sketch Ellipse
If anyone, especially a developer could tell me how Fusion 360 keeps track of sketch profiles when they are modified by parameters that would be very valuable. It seems for some reason after changing the size of the ellipse, Fusion can no longer recognize the profile as the same entity.
Any help would be greatly appreciated. Screen cast is attached and I will upload my model to the post.
Thanks!
-Alterius
