Announcements
"Get All Latest" won't resolve unspecified out of date component
The assembly shows that it has an out of date component, but it doesn't show which one it is. It prompts me to roll back until before the last "Remove" feature, even though there aren't any "remove" features in my design history.
Rolling the rollback bar all the way back through each feature and using the "Get All Latest" command doesn't fix it. I've attached a screencast of the error still persisting even when the rollback bar is at the very beginning of the feature history. Is this somehow related to Milestones, perhaps?
Thanks in advance for any help you can give me. So far it hasn't affected anything, it's just annoying.
bharamk
Hello @Anonymous ,
Thanks for sharing your concern regarding to Get all Latest functionality. From the error it seems that 1 component is removed. When you move timeline to end do you see any component out of date? If not, could you please share following information for further investigation,
1) Design link
2) Diagnostic files
Please go through below contents if you aren't aware,
How to share a Fusion 360 design
How to collect the Diagnostic Log Files for Fusion 360
Thanks & regards
Ketan Bharamgunde
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
Thanks for the reply! Unfortunately, I cannot share the design as it is proprietary. But, after a few restarts, edits/saves of the linked files, the error has gone away. I wish I could help explain what made that happen, but it's all fine now. I suspect it had something to do with In-Context Assembly Edits.
Much obliged.
bharamk
I am glad to hear that your problem is resolved. Have a nice day ahead!!
Thanks & regards
Ketan Bharamgunde
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
reedfaganNUXK3
I ran into a similar issue. When I opened the file of the inserted component, made it play through its modelling history, and re-saved it, the issue was resolved in the assembly.
