Announcements
"Error: loop does not contain given vertex" when adding a Fillet
dezdan
dezdan
While trying to add a simple fillet to a shapes corner, I receive the error "Error: loop does not contain given vertex". There is very little info on this error. The matching corner on the shape I was able to add a fillet without issue. Has anyone else encountered this error and found the cause?
jeff_strater
please share the model here, impossible to tell more without seeing the model, and knowing what edge(s) you are trying to fillet, and to what radius.  Thanks
Jeff Strater
Engineering Director
dezdan
Thank you. What is the best file type to share the design (personal use version)?
jeff_strater
Thanks.  Export as "Fusion Archive (F3D)", and attach the F3D file here.
Jeff Strater
dezdan
Thank you. File attached. It is the lower front right corner; settings in the screen shot. This is my second design ever, so still learning and trying to figure the error out.
jhackney1972
If you edit the first sketch, in your timeline, removing the two Coincident sketch constraints and then replacing them in a certain order, will allow your to edit the edge in question.  The Screencast will show the process.  Repaired model is attached.
@jeff_strater I really think this is a flaw in the application and should be looked into further but of course, that is my opinion.
John Hackney, Retired
dezdan
Thank you John! I appreciate the break down and steps you outlined on how to fix the problem!
