"clone" Fusion360 installation from desktop PC to laptop PC
AndreaA71
Message 1 of 8
AndreaA71
Good morning, I'm Andrea from Italy, I use Fusion 360 (non commercial license) mainly in my desktop PC but sometimes it happens that I have to use it from my laptop. Is there a way to "clone" the entire Fusion 360 workspace form the desktop PC into the laptop PC? With workspace I mean the whole add-ins list installed, the environment preferences and the UI customization....could it be done? Maybe "brutally" copying some folder?
Thanks and regards
Andrea
Replies (7)
Message 2 of 8
mohammed.aliTDPXK
Hello @AndreaA71 ,
At present we dont have any such cloning feature I guess. But when you switch from desktop to laptop you should be able to see all workspaces working fine and without any issues. For external adding you will need to install it on your laptop as well.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 3 of 8
AndreaA71
Thanks! Ok for the add-ins but isn't possible to "clone" (or export or copy, name it as you prefer) the UI customizations? Toolbar etc.?
Message 4 of 8
mohammed.aliTDPXK
Hello @AndreaA71 ,
Thats a good point! Let me check with the team and get back to you on this.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 5 of 8
mohammed.aliTDPXK
Hello @AndreaA71 ,
The preferences actually gets saved with the application and what you set in desktop will be available in laptop as well if you log in with same login ID 🙂
What you need to do is :
  1. Set preferences as you like on desktop.
  2. Close the application at desktop and wait for about 5 min
  3. Now login on laptop with same credentials what you used on desktop
  4. The preferences changes will be available to you.
Also can you elaborate what UI customization you are changing? These should also be available I guess if you follow the above steps.
let me know if this helps.
Let me know if this helps.
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 6 of 8
AndreaA71
Hi, in the UI I've customized the toolbar (added some buttons of some features) and this customizations are not synced in the laptop...
Message 7 of 8
mohammed.aliTDPXK
Can you try with the steps I gave you?
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
Message 8 of 8
AndreaA71
I have done exactly what you suggested and unfortunately the customizations for the toolbar has not been synced between the 2 PCs
