"3D Print" button grayed out.
juancarlos.gv7
Observer Observer
juancarlos.gv7
Observer
Observer
So after updating to Fusion360 - 2.0.4095, the 3D Print button won't work anymore. After updating, I used to click on it, select the body I wanted to print and send it directly to Cura but now it won't even let me click the button. Please help!
Thanks in advance.
3D Print button not working3D Print button not working
ryan.bales
Autodesk Support
Autodesk Support
You might need to restart Fusion again. It looks like you have a message in the Job Status at the top of the screen.
Ryan Bales
Fusion 360 Product Support
yabezus
Observer
Observer
Yes, it's true! Disappeared. Now this export works directly through the right click on a Component > Save as STL. And at the new window, I see the connection with my printer.
Too bad they killed the button. 😞
It seems it may be locked out when the license goes out of date, had the same issue, and noticed mine had, just a quick reactivation should fix it (even better if you are using it non commercially, as its free)
