Announcements
Quickly select entre sketch for 2D contour
DenzilSDavies
DenzilSDavies
I have a sketch I would like to use to in manufacturing to 2D contour cutting on the line. The sketch has a lot of lines to it will take quite a while to select everything and I wondered if there is a quick way to select everything in the sketch.
jhackney1972
When you go to select your geometry, for the 2D Contour toolpath, simply expand the model, in the Browser and select one or more sketches from the model.  The Screencast will show this.
John Hackney, Retired
DenzilSDavies
Thank you.
