Announcements
Question about Fusion 360 machining extension.
uaso7
Observer Observer
uaso7
Observer
Observer
First of all, I appreciate to people who read this post.
I have question that 'Is there difference between normal Fusion 360 and Fusion 360 machining extension?'.
If there is, could you explain it more in detailed?
I want to refer cycle time data on the program.
and should I buy for using Fusion 360 and Fusion 360 machining extension both?
My English is bad. Sorry.
Thank you.
kieran.gill
Fusion 360 Machining Extension consists of a specialised set of additional functionality  The extension can be purchased inside of Fusion 360 . It boost the core CAM capabilities of Fusion 360 with access to advanced 3- and
5-axis strategies, toolpath optimisation and process automation.
Here is a link to more information about it : https://www.autodesk.co.uk/products/fusion-360/machining-extension
Here are a few webinars we have done which may help you to make the correct design as to whether the extension may be right for you :
  1. https://www.youtube.com/watch?v=LTW5PH8EaVg
  2. https://www.youtube.com/watch?v=W_fQs8xpX0g
  3. https://www.youtube.com/watch?v=2XXbXMFmwzA
If you want to sign up for a 7-day free trial of the extension then follow this link
https://www.autodesk.com/products/fusion-360/extensions#trial
By following the link above for the free trial, we will also put you in contact with a member of the team whom can better understand your processes and workflows and may be better placed to help advise you what extension features will be most suitable and applicable to you.
Kieran Gill
Technical Consultant
