I'm trying to project onto a curved surface, but I'm getting the "projecting onto same sketch" error. In the attached picture, I'm projecting Sketch 17 (the small rounded box) onto the curved surface (Body 2, defined by Sketch 12 and joined with the profile from Sketch 15). I've tried adding new offset planes and new sketches, and no matter what I do, I get the same error.
I thought the problem may have originated because the projected sketch geometry (Sketch 17) was originally derived as an offset of the shape in Sketch 12, but I have deleted and rebuilt the projected sketch manually and I'm still getting the error.
I've even tried adding a completely different offset plane and circle sketch, and projecting it onto a different surface exactly as described in the docs (https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Pro...), but I still get the same error!
What am I missing?
