Projecting geometry not working properly I NEED TO GET SOME WORK DONE SO I DON'T GET FIRED
FrodoLoggins
Advisor Advisor
FrodoLoggins
THIS IS A WORKAROUND FOR A WORKAROUND AFTER MY OTHER WORKAROUND FOR A WORKAROUND ALSO NEEDED A WORKAROUND. FIX THIS. I'M PROJECTING WITH THE BODIES FILTER. WHAT IS THIS:
THE BODIES FILTER!!!! CLOSE THAT!!!!
I CAN'T KEEP TRYING TO FIND WORKAROUNDS FOR WORKAROUND FOR WORKAROUNDS FOR EVERYTHING I NEED TO DO. PROJECT THE THING BECAUSE THE CONTOUR SELECTION IS MESSED UP.
I CAN'T GO 5 MINUTES WITHOUT NEEDING TO WASTE 30 LOOKING FOR A WORKAROUND
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
TheCADWhisperer
@FrodoLoggins
I recommend working with Capture Design History enabled.
Can you ask your supervisor to join this discussion?  (I think we can avoid risk of getting fired, but I will need your supervisor’s support.)
