I have read several of the posts on this topic and played and replayed Jeff Strater's pseudo-embossed video, but I still can not achieve the desired result on my own drawing.
Illustration 1 shows a carriage door. I need to create the small gap that would be found between the door and the carriage frame.
Because the lower part of the carriage has a tumblehome curve, firstly, I created an offset plane laid on the flat upper area of the carriage. I then drew the door outline, offsetting it by 0.2mm for the gap and selected the area thus created. I then made an extruded cut to a depth of 0.2mm, but it was apparent that the cut did not extend all way round the door. This can be seen in illustration 2.
If I increased the cut depth, I was able to make an extruded cut all round the door as shown in illustration 3.
However, I simply could not make a projection of the door gap, because try as I might I could simply not select the gap between the two rectangles when in the projection mode. Either one of the rectangles could be picked, but not the area between them.
Why is this, how do I work around it?
Keith
