Fusion Support
Projected geometry moves when dragged?
2 REPLIES 2
RG_Productions
72 Views, 2 Replies
I have notice sketches becoming less stable. With blue geometry being the enemy in designs, recently I have found previously fully constrained sketches showing up with blue. My go to method of resolving is by dragging and redimensioning/constraining where required. Today when dragging the blue the projected geometry went along for the ride?
2 REPLIES 2
g-andresen
in reply to: RG_Productions
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
@RG_Productions
Can you Attach a *.f3d file here that exhibits this behavior?
If unconstrained parent geometry is moved, then projected child geometry should move with the parent. This is logical behavior.
Having said that, I have not seen examples where fully defined geometry becomes unconstrained without user input except in cases of overly complex sketches.
One thing I note from your image is that thin feature might simplify your sketch, but there also might be good reason for using Offset.
