Announcements
Project with Construction not working anymore.
HarrisonClassic
HarrisonClassic
I think a bug has crept in.
When creating a sketch and projecting a face with construction lines turned on, the resulting geometry is not construction lines.
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
jeff_strater
hmm... it works in a simple case.  I'm not sure what is different, though.  Can you see anything?
Jeff Strater
Engineering Director
HughesTooling
It does this if you  have Auto Project enabled. @jeff_strater I noticed if you project the face into a sketch with auto project enabled you end up with a single outline, in the past you used to end up with 2 sets of lines. The new way is definitely an improvement, when did it change? @HarrisonClassic Most users turn auto project off because it tends to project more than you need and adds clutter to the sketch.
Mark Hughes
Owner, Hughes Tooling
