Announcements
Program hangs on .stl export
sellmaktherational
Observer
sellmaktherational
Observer
Observer
Since the recent cloud saving limit change, any time I attempt an export to .stl, the program hangs. In order to see if I was being impatient, I left it overnight (9 hours) and it was still unresponsive.
I can export from the file menu with no issue, but not through the design dialog.
Here is the model that hung on me 6 times this morning.
https://a360.co/3cn30Sl
jodom4
Hey sellmaktherational,
This is a known issue that we're working on. As a work-around, you can just right-click on the body or component you're trying to export, and select "export as STL". That will do it locally which is much faster.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
