Announcements
program does not load fully
dinkydi63
dinkydi63
When I try and load a sketch from the Data Panel it does not seem to load completely, the blue circlr keeps revolving in the data panel. Previously it would stop when completely loaded. modifying a drawing then saving it, is also a problem it retains the previous version and discard changes. What to do?
mohammed.aliTDPXK
Hello @dinkydi63 ,
Sorry for the trouble you are facing.
Can you please collect log files for the issue you are facing and attach here?
Open Fusion fresh--> Repeat the issue you are facing--> Go to Help->Support and diagnostics-->Log files--> show in finder/folder appears -->copy from the location and paste the files here.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
dinkydi63
Hi Mohammed,
Thank you for your response, I must admit I am not very clever with
computers so I apologise for the delay in responding to you, as I had some
difficulty in getting the info!!
Anyway, I hope what I have attached is what you requested and you can
decipher then problem.
Thank you and regards
George
