problems with fusion 360, I can't open the program but I can't even uninstall i
Message 1 of 1
Hello everyone, I hope to be able to solve it here, I have a student version of the software and it
is ten days that fusion360 does not go online, I have tried everything that is reported in the autodesk
guides but nothing, I have not solved. I uninstalled the program and deleted the folders from disk C :,
I reinstalled and the warning appeared '' the program does not have all the packages to go online, check
the connection and try again '' the program then crashes. I followed the autodesk guides again but
nothing. I have uninstalled everything again and deleted the folders, but again without any result.
I contacted autodesk assistance via chat but they didn't know how to help me, in fact ... they made
me install the flach version, obviously it doesn't solve the problem for me because my work files are
in the cloud. I then tried uninstalling and deleting the folders of any Autodesk product, including
Autodesk app and reinstalling everything. Now when I start the installation the app tells me "do you
already have the latest version installed, do you want to open the program? if I put no ends the
installation process, if I put this error comes up and the program closes. Ah obviously the program
is not installed and does not appear in the list of programs to be uninstalled using the menu in the
control panel, let alone ccleaner and idem with revo uninstaller. I'm desperate, help me
first reinstallation screen 1first reinstallation screen 1first reinstallation screen 2first reinstallation screen 2current situationcurrent situation
Replies (0)
