Fusion Support
Problems with editing feature on the timeline
4 REPLIES 4
gregorychard
129 Views, 4 Replies
Problems with the editing the history
This file that I'm doing is the first, and hopefully the last one.
What has been happening is that I may have 8 bodies, but when I do an edit in the timeline, the amount of bodies goes to 3, or another amount. But when I redo the same edit, the bodies numbers are the same or even more, but different to what I have done. The change to the bodies could be, that one of them may have be separated from each other (from a combined function) I did before the edit on the timeline.
This also happens when I do remove feature.
This is only happening only on one of about 50 component, that I'm using on this file.
I will NOT USE THIS COMPONENT again.
Could it be a faulty command in making it?
I have made a final combined bodies from it and copy it to another component. So far so good.
Should I remove the component and mark it on the timeline somehow?
Greg
Tags (2)
4 REPLIES 4
g-andresen
in reply to: gregorychard
Without insight into the design and naming of the affected elements, conclusions about causes and hints for solutions are not possible.
Please share the file.
File > export > save as f3d on local drive  > attach it to the post
günther
No, from your problem description it sounds like you should Attach your file here as suggested by @g-andresen so that one of the experts here can give you proper step-by-step instructions.
G'Day from Australia
I have tried export a file of the component, by there are no correct file format that I can use.
Here is a screen shot of trying to export.
I do not know what to do, except for a complete uninstall and new re-install of Fusion 360.
thank for your assistance.
Greg Chard
g-andresen
If there are linked components in the design break the links with right click > break link (only for export) and follow the hint in # 2.
günther
