Newbie on Non-commercial version...
I've encountered some behavior with coincident lines that seems problematic ....
Working on a sketch in Design panel. I needed to create a construction line at an offset from an existing line (and perhaps due to lack of knowing a better way), so I create a perpendicular construction line with the desired spacing and then created two lines off the point (one in each direction). In one case I ended up two construction lines overlapping in one place. When using the Circle tool, the pointer would not lock on to an intersection between a normal line and the overlapped part of the construction lines. After deleting both coincident lines and reconstructing a single construction line, it worked normally.
Another case with the same idea about creating an offset construction line as above, but in this case, using the circle tool, got an error and the details said something about the profile was not created because the compute failed. Similar clean up of deleting construction lines and recreating, and it worked thereafter.
Another case where I copied two sketches (copy/paste) into a third and moved them around so that they were touching on one edge. This resulted in four coincident normal lines at the edges (haven't check to see if somehow there were two on the edge of the source sketches). At any rate, when using the circle tool, the second point would lock on the coincident lines but the program would hang forever. Terminated fusion, re-opened the file, deleted 3 of the 4 lines and it worked OK again.
Whether there are any documented rules about not having coincident lines or not, perhaps the program should either deal with them transparently, or provide a warning about them when created, or at least provide some information when the program trips over them without just hanging or having a non-specific error.
