Problems with Chamfer and Sweep
I am a very newb to Fusion 360 and I am trying to make cookie cutters for my daughter. The problem (this time) is that when trying to make a sharper edge on the cutting edge of the cookie cuter, I get one of a dozen errors depending on how I go about doing it. Chamfers seem to fail at different places depending on which way I select paths, but I cannot get a full chamfer. I have also created a small right triangle profile along the top edge and tried to run a sweep. I got quite a bit further with the sweep, but not quite all the way around.
The V3 sample below is the cookie cutter I am working on now. It shows the surface I am wanting to sharpen. The V4 sample shows how far I got. I used two profiles and got most of the edge like I want all the way around except for two small points at the top. I'm guessing that the two places where it did not sweep are just too sharp. At any rate, I would appreciate suggestions to fix it.
