Problems since last couple of updates
Since the last updates a couple of days ago and yesterday, when working in the main screen the work page flickers when moving mouse and when carrying out an action disappears and the background screen appears. Once the action is completed the work screen reappears. when you move the mouse to the tabs and icons etc. at the top sometimes the work screen will flicker on and off showing the background screen as well.
dsouzasujay
Hi @Anonymous ,
Do you mind sending up screencast video and show what is happening. At this stage, I believe you have updated  fusion build version to 2.0.10148+.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Good morning, I can send you a screencast no problem. I installed it and recorded some time but doing that has caused a new problem when screencast is running it seems to make the work area go black. I had to let screencast resize the work window to be able to record.
I do have some recording but as never used it before can you help me to send it to the right place!!
I've titled it Problems since last update and in sub category picked troubleshooting.
In the "share with box" which choice do I use?
Bruce Seaton
dsouzasujay
Hi @Anonymous ,
You can select Public, after that you will receive a hyper link to the email.
Copy and paste hyperlink here to the next reply.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
I cant find anywhere to make it public, but clicked share to email and got this hyperlink.
Best Regards,
Bruce Seaton
https://knowledge.autodesk.com/profile/LLYO1UQ2NRERX/screencasts/shared
