Announcements
Problems making drawing of imported FBX file
lhaahjem
lhaahjem
Hi.
I have imported 3d map data (in fbx format) from a property where i want to design a boat house. When I am finished with the design I want to make a drawing in 2d out of it, but I tried to go from design to drawing in Fusion and it does not work. See attached picture and 3d model.  I see that the warning says "no solid bodies or sketches". Is there a way of converting to solid bodies and sketches? And are FBX the best format when I do not have access to other software then Fusion or Inventor?
dsouzasujay
Hi @lhaahjem ,
Your design does not have solid bodies, it has Surface and Mesh bodies.
How did you got this fbx file, From which software you have created this file?
If possible please export using step format and try to create a new drawing.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
lhaahjem
Hi.
I downloaded it from a supplier of 3d maps. These are the formats that I can choose from:
3DS
3DPDF
CityGML
Collada
DWG/DXF
FBX
FMEAR
gITF
IFC
KML/KMZ
LandXML
SKETCHUP
STL
Wavefront
TXT
I guess many of these formats are best to open in an arcitechture program such as BIM360 or Revit etc., but I was hoping to edit my boathouse in to one of these formats in Fusion 360, Inventor which is available software through my job (or import and convert to other format in fusion or Inventor). I tried to import STL in fusion, but that did not work.
dsouzasujay
Hi @lhaahjem ,
Please download the STL file format and attach here to the next reply.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
lhaahjem
See attached.
