Fusion Support
problem with the viewing of my models
1 REPLY 1
dkerr12BW2KP
42 Views, 1 Reply
when I I'm trying to look at my models from a different angle, I generally use the cube at the top right corner, but recently I have noticed that while turning the cube the model will unexpectedly point in a seemingly direction. this only started happening a few weeks ago and it's been very annoying. please fix or tell how i can fix it if possible. thank you!
1 REPLY 1
jhackney1972
in reply to: dkerr12BW2KP
I cannot fix your View Cube, but you can view your model very effectively using the Free Orbit command.  Use the embedded compass to select your direction of motion.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
