Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
problem with the opacity of bodies
3 REPLIES 3
henrik.laufer
316 Views, 3 Replies
Since few weeks my desinged bodies are transparent. I tried to change the opacity, activated and deactivated the component and changed the design preferences. Additionally, I tryed fusion 360 on differend workstations and in the browser. Nothing helped. Any other ideas?
Tags (2)
3 REPLIES 3
I am guessing you have accidentally gotten into Wireframe mode.  Take a look at the video and see if it helps.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask.
John Hackney
Retired
This solved the problem. Thank you
