Fusion Support
Problem with surface deletes in Surface workspace
3 REPLIES 3
StephenCim-001
140 Views, 3 Replies
Hi All
Have not been designing in a while, but I've started reworking some of my old models.  I use bit of Surface modeling in my design to adjust the look of faces after I've done with solid modeling.
Has never been an issue before, I have always been able to switch to Surface workspace and delete a single face out of a body, but the latest F360 (2.0.15775) seems to perform a chain delete instead of a single face delete.
i.e
select a face
select delete
whole model to right is delete , not just the select surface
Has there been a change in behavior?  I don't recall having this issue before. (started using F360 2016/17)
Cheers, stephen
3 REPLIES 3
Hmm...  I think you are right.  I will investigate...  Sorry for the change.  I guess in the short term, unstitching that face and deleting it will get you where you want to go.
[edit]  I can reproduce this with a simple case.  Created bug FUS-126863 for this.  Thank you for bringing it to our attention.  Hopefully, because this is a regression, a fix will be available soon
Jeff Strater
Engineering Director
@jeff_strater I've reported this bug a while ago ...
Peter Doering
Thanks , I have been unsticking faces in the mean time, sorry for the late reply 🙂
