Problem with patern on path
s.smeets
Observer Observer
s.smeets
Observer
Observer
Stranges thing, I made a little belt and before I apply it, it looks good. and after applying it takes an all other way.
someone knows how this is possible? thank in advance
TheCADWhisperer
@s.smeets
s.smeets
Observer
Observer
Thank you for the responce, just uploaded the file.
jhackney1972
When you create the belt tooth feature, do not use a Join in the Extrusion as the operation.  This will result in the complete belt to be selected when you Pattern on Path using feature.  Model is attached.
John Hackney, Retired
s.smeets
Observer
Observer
Thank you very much sir, appreciate the quick help.
