Problem with finding folder for custom thread profiles
peteGCAB6
peteGCAB6
Hi All,
Someone on this forum very kindly made me some custom thread profiles for helicoil holes. To use them, I had to put the XML files in a folder in the computers library (using mac). Unfortunately, every time Fusion updates or changes, it looses the custom thread data so you have to replace them in the folder, but i'm having a problem finding it this time.
To find the folder, I follow the very long arduous complex path from this article:
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/Custo...
The path is:
Macintosh HD> Users> [Username] > Library > Application Support > Autodesk > Webdeploy > production > [Version specific ID] > Then right click on "Autodesk Fusion 360" and choose Show Package Contents > Contents > Libraries > Applications > Fusion > Fusion > Server > Fusion > Configuration >ThreadData
The problem is, the trail goes cold when I get to Contents. There is no Libraries folder, just a folder called 'Helpers' which only contains a file called AcCoreConsole.app
So, I cannot find the ThreadData folder to put the XML files in.
Can anyone help me find the folder?
Thanks.
HughesTooling
There's an add in here that will keep your custom threads up to date with Fusion.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1725038115223093226&os=Mac&appLang=en
Mark
Mark Hughes
Owner, Hughes Tooling
