I'm having trouble with Extrude from Object. I'm trying to model this helmet so I can carving it on my CNC router.
I created a simplified version of the helmet to test with.
I also made a sketch of the "star" and the hole for the face.
Here's the problem. When I try to extrude the star from the surface of the helmet, I can't select the entire star profile. I have to break it into two parts, one for the dome and one for the tapering sides, and extrude them separately. The same goes for when I try to push the face into the helmet.
Doing the extrudes in four separate operations sort of works, but it's inconvenient and it leaves an odd artifact in the star where the part extruded from the dome meets the part extruded from the taper.
Am I doing something wrong? Is there a better way to accomplish this?
Here's the exported design. Thanks.
