Problem with Combine Cut
gillesht
Message 1 of 14
gillesht
I want to eliminate the bottom part of a model. I'm using the Combine Cut function without success. Can anyone help me. I'm a new user. I'm including my model.
Best regards.
Replies (13)
Message 2 of 14
TheCADWhisperer
@gillesht wrote:
I'm a new user.
I recommend that you fully constrain each and every sketch.
Back in a minute...
I would simplify sketch and use Shell instead...
Did you really really want this to be non-uniform thickness?
Forget you ever saw the Move command - if you feel the urge to use it - STOP and ask questions here.
Message 3 of 14
TheCADWhisperer
Edit Sketch1 in the Attached file.
What color are the lines? Blue or black?
Message 4 of 14
TheCADWhisperer
Turn on Analysis>Section1.
Is the part uniform thickness?  Even in the filleted corners?
Message 5 of 14
gillesht
Blue
Message 6 of 14
gillesht
Yes, it should be 5,5 mm.
Message 7 of 14
TheCADWhisperer
@gillesht wrote:
Blue
On my file, or on your file?
Blue lines should keep you awake at night.
See Attached file Cone.f3d
Message 8 of 14
gillesht
On my file
Message 9 of 14
gillesht
I thank you very much for yor help. I will use the Shell function.
Best regards.
Message 10 of 14
TheCADWhisperer
I suspect that you will have a lot more questions on this design.
(I haven't even figured out what it is yet.)
Don't get completely lost in a deep hole before asking additional questions.
Message 11 of 14
gillesht
The part is a lamp-shade, I have to get rid of the skin at the base of the part. I've tried with Combine-Cut without success. Do you have another approach?
Best regards.
Message 12 of 14
davebYYPCU
Shell and
select the faces you don’t want, before the OK button.
Might help....
Message 13 of 14
TheCADWhisperer
@gillesht wrote:
The part is a lamp-shade.
 Yikes!  You should have stated that up front.
That makes the job about 10 times easier (See Attached).
Message 14 of 14
gillesht
As you said, very simple indeed.
Thanks for tour help. That's what I call a fast tutorial.
Best regards.
