Hi there,
I’m a beginner and I’ve got a problem with changing a dimension (d104) in Fusion 360. I couldn’t find an answer in the internet. The dimension already exists, but I have to add 30 mm to it. And Fusion always tells me that that’s not possible: Failed to solve. Please delete or modify the following constrains/ dimensions: d104 : 120mm. I just don’t get what I’m doing wrong. I can edit other dimensions in the sketch. It’s probably a stupid little mistake.
But when I’m already writing a post here, I’ll add two other questions:
Why is the slot with the dimension d152 not fully constrained?
And why do center to center slots delete the dimension you’re setting when you’re creating them?
The file I’m talking about is attached.
Thank you in advance.
