problem intalling Fusion 360
thadtyrean
thadtyrean
Fusion does not install, the log file is attached. Please help.
I had Fusion 360 working but then had to restore my computer. Afterwards, Fusion 360 does not install.Capture.PNG
jhackney1972
Your log file did not attach, please try again.
John Hackney, Retired
thadtyrean
Thanks, I do not need help.
I got it to work by reinstalling windows
thadtyrean
It is all fixed - Ignore this post
jhackney1972
You can close your own posts.  When you are logged into the Forum, find your post, and look a the bottom of the message that solved your issue, and select "Accept as Solution".  This takes it off the board and allows others to search for a solution to a similar problem.  Since you did not post your solution, this will not be the case.
