problem instzlling fusion
@hattrixmould This should take care of this problem.
1. Make sure that Fusion installer is not running in task manager
2. Go to C:\Users\user\AppData\Local\ Autodesk\DELETE the following folders – Webdeploy,Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
