Problem Installing Fusion. The read operation timed out
eugenio_digr
Community Visitor
eugenio_digr
Community Visitor
Community Visitor
I'm trying to install fusion360 on my laptop and I keep getting these error: The read operation timed out.
I've provided the logs. Please help
RajkumarIlanchelian
@eugenio_digr Our engineering team took a look at the logs files (thank you for providing them) and it appears you may be won a very slow network when the packages are not able to be downloaded correctly? Can you or is it possible to switch to a different network (on a phone hotspot for example) and see if that helps with the install?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
