Problem installing fusion 360
I downloaded a zip file of fusion 360 student version and extracted, then why trying to install,an error message usually come up. Please help  
RajkumarIlanchelian
@Anonymous Can you go to the "Open log file location" and attach the log file that is generated?
This error is usually a problem with network (sometimes the package downloaded might not be complete as well). Refer to this post and see if that helps .
https://forums.autodesk.com/t5/fusion-360-support/install-error-urlopen-error-lt-urlopen-error-errno-11001-geta/m-p/9426140#M83971
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I had older version and it wont install
RajkumarIlanchelian
Are you able to install now after downloading the latest version?
Autodesk Fusion
Join Fusion Insider
CAn I have the link for the latest fusion 360
jhackney1972
If you are trying to install Fusion 360 as a student go here.  If you are trying to install Fusion 360 with a Personal License go here.
John Hackney, Retired
