Hi @danielcorlett83,
Welcome to the Fusion 360 Community!
I believe your proxy server is coming into play here and prohibiting Fusion from reaching the correct servers. As you can see in the code snippet:
urllib.error.URLError: <urlopen error <urlopen error [Errno 11001] getaddrinfo failed>, url:https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f7a6f4a289729f/full.json>
2017-09-24 17:21:36,523 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2017-09-24 17:21:36,525 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: S_I: MjMuMC4yMDAuMTg1
2017-09-24 17:21:37,346 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.netlib - WARNING :: Failed to get public ip address <urlopen error [Errno 11001] getaddrinfo failed>
2017-09-24 17:21:37,347 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PU_I:
2017-09-24 17:21:37,347 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: C_PR_I: MTkyLjE2OC4xLjI=
2017-09-24 17:21:37,579 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: Local DNS: U2VydmVyOiAgZGxpbmtyb3V0ZXINLCBBZGRyZXNzOiAgMTkyLjE2OC4xLjEN
2017-09-24 17:21:38,401 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.netlib - WARNING :: Failed to get speed data <urlopen error [Errno 11001] getaddrinfo failed>
2017-09-24 17:21:38,401 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: Network Speed:
2017-09-24 17:21:38,401 - MainProcess(3984) - InstallDriver - adsk.dls.streamer.process - INFO :: Proxy enabled True
You are failing to reach certain URL and getting your IP address. Can you please review our network troubleshooting guide here with respect to proxies and ensure that the correct URL's are white listed. Also, if you have already done that, try resetting your router - it does seem strange that it cannot obtain your IP address.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
