Problem installing Fusion 360
I can t install Fusion 360.
Ihave tried to uninstall all the Fusion 360 files. But i still get the message:
CorruptError: database disk image malformd.
dsouzasujay
Hi @Anonymous ,
Delete the Webdeploy folder from below location
  • Windows: C:\Users\<username>\AppData\Local\Autodesk
  • Mac: ~/Library/Application Support/Autodesk/
Reinstall Fusion 360.
Let me know if it works
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Hello Sujay,
Thank you for your reply.
I don't have the Autodesk folder 😬
dsouzasujay
Hi @Anonymous ,
Did you tried Automatic clean uninstall tool of Autodesk Fusion 360?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
I tried to install the Clean uninstall Tool but now i get the message i don t have permission to open this app. And i cannot overrule this in the settings. So the Clean uninstall tool doesn't work for me. Is there an other way to do this?
dsouzasujay
Hi @Anonymous ,
Sorry for the delayed response.
Try to disable antivirus and firewall temporarily and run Automatic uninstall tool.
If you still face problem, Try manually uninstalling fusion 360 and clearing files.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
