problem in creating sketch
yashzzz
Observer
yashzzz
Observer
Observer
i am new and i am trying to create sketch but there is nothing showing on the screen it is blank and no planes are visible in online tutorials whenever they click on sketch 3 axis shows up . But in my case it doesn't come i cannot see any planes on the screen
davebYYPCU
There is an eyeball next to the origin label in the Browser, click on it to turn it on.
Try again with the Origin visible.
If that does not work, then it might be graphic driver problem.
Might help….
yashzzz
Observer
Observer
that didn't work . do i need to update graphic driver ? . At one time it suddenly start showing up and i was able to make some design and then next time i opened it shows the same blank . like i selected line it is showing me its dimension but line is not visible itself.
g-andresen
1. try preferences > graphic driver > change  to open GL
2. Update your graphic driver
günther
yashzzz
Observer
Observer
thanks that actually worked .. can you please tell me what was that i changed and why it worked .
g-andresen
direct x and open GL are graphic drivers with different focuses
have a look Here
günther
