Announcements
Problem exporting model to .dxf (false splines to center)
l.p.1999
Observer
l.p.1999
Observer
Observer
Hey,
im just a hobyist.
I want to cut the file I drawed on my lasercutter, bist my dxf incude false points in the splines.
I made a 3d model, projekted the front faces and rightkilckt and export as .dxf.
Am im making somthing wrong?
jhackney1972
Importing your supplied DXF into Fusion 360 and AutoCAD bring up good images.  If the image you are posting is from your Laser Cutter, I would suspect it is not translating correctly.
Fusion 360 ImportFusion 360 ImportAutoCAD ImportAutoCAD Import
John Hackney, Retired
l.p.1999
Observer
Observer
Thanks, can i somehow change the .dxf standart that fusion uses?
i read online that there are older and newer standards but I cannot find an option in fusion or lightburn.
jhackney1972
Not aware of any way to change the way Fusion 360 exports DXF.  Can you use Fusion 360 to generate your laser toolpath?
l.p.1999
Observer
Observer
thangs for yout help, i´ll try. but it seems more complicated than with my other Software.
